5/5/2012 10:01 PM | |
Posts: 559 Rating: (87) |
What is the difference between SIPLUS & Normal Modules for S7-300 as well S7-400 PLC? Where SIPLUS Modules can be used? |
5/5/2012 10:23 PM | |
Joined: 7/18/2011 Last visit: 10/9/2023 Posts: 521 Rating: (91) |
Hi SolutionFinder, Siplus modules are kind of ruggidized version of normal modules and can be used in more extreme conditions of temperature, vibration, ... You can a lot of information about Siplus modules in this FAQ Kind regards, BV |
5/6/2012 7:00 AM | |
Joined: 12/1/2009 Last visit: 9/5/2024 Posts: 672 Rating: (147) |
Dear SolutionFinder , in automation business you will face different areas and environments for yourapplication. To fit the standard products for thesespecial environments they need to get modified. You can see thatas a sort oftuning for yourenvironment.In example, some ares havea higher ambient temperature and youcannot justplace a standard PLC to work in there. The modified/tuned productsare called"SIPLUS". Take a look at the SIPLUS websitebelow. You will find not onlyPLC's there. https://www.automation.siemens.com/mcms/topics/en/siplus/Pages/home.aspx Regards. |
Give us your feedback and show us your respect! |
5/6/2012 9:20 AM | |
Joined: 5/28/2008 Last visit: 9/9/2024 Posts: 4515 Rating: (839) |
Hello, Siemens Provides two types of products. Standard type or let us call normal is always used for normal conditions. SIPLUS is used for extreme conditions.
In thislinkyou will found the followings:
Hope this helps. |
5/16/2012 6:12 AM | |
Posts: 103 Rating: (6) |
thanks this answers my question too.... i was also wondering the difference between SIPLUS & Normal modules.... |
