7/14/2014 9:24 AM | |
Posts: 206 Rating: (22) |
Hi PILearner, in general you can say a belt scale only measures the flow of material that is running over the belt. Also the total amount of material will be measured. A weight feeder is doing the same, but the belt and/or material feed will be controlled to get a certainmaterial flowthat you have set as set point. Attached you find two sketches to illustrate this. On the page www.siemens.com/weighingyou find more information about weighing electronics and mechanics for belt scales and weight feeders. Regards ABenno AttachmentD:\temp\Belt.zip (212 Downloads) |
7/15/2014 2:46 PM | |
Joined: 12/13/2012 Last visit: 10/5/2023 Posts: 124 Rating: (45)
Hi PILearner , |
