3/17/2009 12:36 PM | |
Joined: 3/21/2006 Last visit: 2/6/2025 Posts: 10239 Rating:
Hello And explanations from manual is not usefull? regards |
3/17/2009 2:09 PM | |
Posts: 103 Rating:
first I want to thank you alot for your attension, second in PP17II side in I adjust the paramters as following : MPI address: 1 Baud rate: 187.5 KBaud Data area type: Marker byte Memory word: 100 Configuring data block: 2 PLC address: 2 PLC type: 300 (S7-300) Highest station address: 126 Number of MPI masters: 1 Attachmentpp17.zip (332 Downloads) |
3/17/2009 3:40 PM | |
Posts: 103 Rating:
thank you Wizard , I execute your suggestion but nothing change , please keep in touch with me till solve this problem thank you |
3/17/2009 3:48 PM | |
Posts: 103 Rating:
thank you Wizard , I execute your suggestion but nothing change , please keep in touch with me till this problem solved . thanks. |
3/17/2009 3:52 PM | |
Hello Could be the reason in hardware? Would you check again cable and connectors? regards |
