4/25/2012 12:10 PM | |
Posts: 241 Rating:
Recently i ve faced the problem that S7-300 digital output module is not generating 24V I've replace the all modules but problem is not solved... |
4/25/2012 12:20 PM | |
Posts: 241 Rating:
LED is glowing In VAT table also the values are correct as physical present |
4/25/2012 12:41 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, Asasked before, all connected as shown in attached diagram? Regards, Marcjan Attachmentoutputmodule 1bf 01.pdf (40 Downloads) |
Problem solved? |
4/25/2012 12:48 PM | |
Joined: 9/29/2009 Last visit: 3/4/2020 Posts: 43 Rating:
Hi Deep, 1. check the wiring of your module. on this link: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=6ES73221BF010AA0&caller=view 2. Go to the object properties of the module & check Under the Address Tab the Process image is defined. All the Best ! AGR |
