6/16/2009 12:43 PM | |
Posts: 76 Rating:
Hi, STEP 7 works under DOS. The com port must be COM1. You are using USB to Serial converter under Windows, under Windows there are many problems. Good luck! |
6/16/2009 2:32 PM | |
Joined: 1/28/2009 Last visit: 1/22/2022 Posts: 21 Rating:
hi! but i use step 5 software |
6/16/2009 2:47 PM | |
Posts: 1064 Rating:
Drive master I think that Naah ment step5 as it runs under dos . Is your step 5 set up to use as511 for communication? |
6/17/2009 8:37 AM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
Hello, Example cable - (usb / tty cable is: usb/rs232 rs232/tty adapter (2in1)) http://www.cdelektronik.de/products/S5_PG-USB/s5_pg-usb.html Look at attachment: ![]() Hope this will helps. Best regards Hristo MIhalev |
