6/29/2021 12:54 PM | |
Joined: 6/22/2017 Last visit: 1/30/2023 Posts: 339 Rating:
Hi Alex, i might not have the easiest solution, but i think as far as i have seen it is pretty powerful. There is a Table (Custom Web Control) provided by Siemens. You can fill it with any data you want, but have to attach the data via Script. So you would have to read out the SQL Database via script (Snippeds are available) and transform the data for the Control. See: https://support.industry.siemens.com/cs/ww/en/view/109779176 Best regards |
6/29/2021 3:24 PM | |
Posts: 4 Rating:
That's great! Thanks ZickZackTIA. I know the capabilites of custom web controls, I have worked with them a little. I thought that a simple task as displaying data into a table would be covered by a Wincc Unified element/control but it seems like it doesn't. I didn't see the "table" custom web control, only the guage one. I will read its documentation and try it! Thanks again. |
