11/10/2006 11:23 AM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating: (151)
Hi Julien This can be done but I do not know how [:(] Until someone else responds maybe thisFAQwill give you some starting information. Salma We dance in a circle and suppose,while the secret sits in the middle and knows |
11/10/2006 12:52 PM | |
Posts: 3149 Rating: (171)
Hi you could have a try with using System Status lists (ssl) http://support.automation.siemens.com/WW/view/en/1214574 nemo |
11/11/2006 1:59 PM | |
Posts: 58 Rating: (1) |
[quote user="Nemo"]Hi you could have a try with using System Status lists (ssl) http://support.automation.siemens.com/WW/view/en/1214574 nemo I am sorry, i have downloaded the pdf file, but there is 756 pages and i don't know what word tu write to search in this document. I am french, and I know what I want in french, but I don't know how to explain this in english...so i don't kow how to search in a big document like this ! Can you help me ? Thanks very much Julien |
11/12/2006 3:54 PM | |
Hi, well my French is a little bit limited but it´s chapter 33 in the English version => chapter 33 (SZL) in the German/French manual. Enjoy your Sunday, nemo |
12/4/2007 9:46 AM | |
Posts: 58 Rating: (2) |
Try this one. http://support.automation.siemens.com/WW/view/en/22727527 Or you programm the Failure OB's manually and set a tag for each event, Or use The Alarm-8P block in S7 Greetings Dreminee |
