9/10/2014 10:58 PM | |
Posts: 24 Rating:
Hello Sandman, I am working with TIA Portal v13, and I'm tryingto do the same asNick, but if I understand I can't do it in the same way. I follow your explanation docs but can't asign the "string tag" to a template_text or template_button. The problem is I can not find the field "Type-->Mode" and then set it to "Output". What I am doing wrong? Can you help me? Thanks in advance, vperezb |
Last edited by: Min_Moderator at: 9/11/2014 10:24 AMNew subject after splitting from /tf/WW/en/Posts/57273#top |
9/11/2014 2:23 PM | |
Posts: 1299 Rating:
Hello, you can do it the same way. you can show the tagwith an "IO-Field", not with a text or button. K!ke |
