5/23/2014 4:54 AM | |
Joined: 1/28/2009 Last visit: 3/25/2025 Posts: 6863 Rating:
Please check the following link for a solution in SCL for S7-300.As the solution is pure arihtmatic equations, it can be easily adapted in TIA Portal for S7-1200. interpolating measured values with polygon and output of function values |
5/23/2014 8:07 AM | |
There are some facts to be shared regarding your question:
Please, try and update, Hamid Hosseini |
5/26/2014 7:28 PM | |
You are right,It is not possible to migrate the whole project without STEP 7 installed and the license.Watch more here What are the prerequisites for migrating STEP 7 V5.x projects to STEP 7 (TIA Portal)?What I can do here , to provide you an SCL source file that you can import it easily in your project.Please wait until I upload the SCL source file.
update: check the attached file and update! AttachmentPOLYGON.zip (510 Downloads) |
5/26/2014 9:09 PM | |
Posts: 60 Rating:
Generate blocks!!! |
5/26/2014 10:07 PM | |
Posts: 60 Rating:
Hi, Making progress........ I have a compile error on FC50. The1200 system doesn't like Block_DB data type....apparantly the S7-300 is ok? As this is for a 1200 system what are my options? i have attached the project so far ![]() Cheers
AttachmentLookup.zip (558 Downloads) |
