10/9/2011 6:44 AM | |
Posts: 26 Rating: (0) |
Dear Smits, Thanks for your reply,no I isolated it and no connection is to this channel, Regards |
10/10/2011 7:36 AM | |
Joined: 3/21/2006 Last visit: 7/26/2024 Posts: 10228 Rating: (1181) |
What about if you force the previous and the next chanels? Best regards, Hristo MIhalev |
10/10/2011 10:45 AM | |
Joined: 10/7/2005 Last visit: 9/7/2024 Posts: 3018 Rating: (1054)
Hello farzaneh since the 6ES7 326-2BF00-0AB0 is a F-DQ module, my question to you is: Are you operating it in Safety or Standard mode? Depending on the answer, can you please verify your wiring of it as per chapter 8.6.2 of the S7-300 ET 200M Distributed I/O Device Fail-safe signal modules manual. Secodn questionL: Was this Outputworking before or is this a brand new setup that you are trying to make work? I hope this helps and please let us know what you find. |
Cheers |
10/12/2011 1:24 PM | |
Dear Amit, Thanks for your reply. The system is working and not possible to check your note. |
10/12/2011 1:26 PM | |
Dear UMENCHO, thanks for your reply,other channels of the module are OK. thanks |
