10/10/2016 2:08 PM | |
Joined: 11/14/2008 Last visit: 5/6/2024 Posts: 504 Rating: (22) |
What you can do is , calculate their MTTF (using MTBF value) and create your maintenance schedule . MTBF is easy to find on datasheets or in excel file like in this link In attachment an excel file which is a startup for you maintenance schedule .. Hope it helps, Regards, Attachmentmtbf_mttr_cal.zip (210 Downloads) |
10/10/2016 3:33 PM | |
Maybe this can be a start to set up what you need:How do you report S7 system errors in WinCC?Getting the Status of the LED Indicators How do you read out the diagnosis data of a PROFIBUS DP slave with the SFC13 "DPNRM_DG" and how do you evaluate the data in the user program?Application Example : Getting the Status for the CPU LED Indicators(Codes) |
Last edited by: OmegaProjects at: 10/10/2016 3:34:40 PMLast edited by: OmegaProjects at: 10/10/2016 3:35:27 PM |
