2/2/2015 9:25 AM | |
Posts: 23 Rating:
So you want to add a documation over the context menu? |
2/2/2015 10:36 AM | |
Posts: 5 Rating:
I want to add this to one of my functions. |
2/2/2015 10:48 AM | |
Posts: 23 Rating:
i found the following link: Providing_user-defined_documentation_enUS.pdf if i understood it you can create your own documentation with several editors (like xml, pdf, txt,...). Then you need to name it with the "name rules" in the document so the function block matches to this documentation. After this it should be possible to open the docu with shift+f1 (ive never tried it before maybe you can tell us if it works). Hopefully it works greetings, deben |
2/2/2015 11:47 AM | |
Posts: 5 Rating:
Ah thank you i will try this and will post the result |
