8/9/2016 7:46 PM | |
Posts: 101 Rating:
Does OP 177B support back up with microSD on 1 GB? |
8/9/2016 8:22 PM | |
Joined: 9/27/2006 Last visit: 2/14/2025 Posts: 12336 Rating:
Hello anonym; From this document, it looks like Siemens panels do not support Micro SD format memory cards: Which external storage media can you use with the current SIMATIC panels and which memory card interfaces do they have? https://support.industry.siemens.com/cs/fr/en/view/21847868 Hope this helps, Daniel Chartier |
8/9/2016 8:59 PM | |
Joined: 1/21/2013 Last visit: 11/20/2024 Posts: 4620 Rating:
Hello, I use this card on OP 177 B but is "SD" card 6AV6671-8XB10-0AX1that is 512 MB, I don't know with some adapter from Micro SD to SD card function. Please have a look the maximum size for various panel https://support.industry.siemens.com/tf/ww/en/postattachments/download/?attachmentId=38423 You will find your maximum size for OP 177B with right code of your panel
Last edited by: Ste39 at: 8/9/2016 9:34:45 PMLast edited by: Ste39 at: 8/9/2016 9:53:43 PMRemoved if OP 177B with SD card 1GB function |
8/12/2016 8:18 AM | |
Posts: 101 Rating:
I backuped using Flexible, Controller, MPI cable it lasted 2 hours (mpi 187kb/sec) and psb file in 16 mb :( |
