9/11/2017 3:35 PM | |
Posts: 5 Rating: (0) |
We have a ROBICON GENIIIE HARMONY VFD equipment in Cartagena Refinery in Colombia, and this equipment has defined “Integral Gain” parameters. However, we don’t know what is the units for this parameter: resets per minute, resets per second, seconds, … You answered me: "We use resets per second. The term is represented by 1/time, so the larger you make time, the slower the integrator will react." However, I still have the following doubt: you say that you use resets per second, but you also say "so the larger you maketime, the slower the integrator will react". Our New Question:So the larger I make "integral gain" parameter (represented by 1/time), ¿the faster the integrator will react? (since time is inverse to the “integral gain” because is represented by 1/time).------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 9/12/2017 9:20:49 AMNew subject after splitting |
9/11/2017 4:11 PM | |
Joined: 9/27/2006 Last visit: 12/3/2024 Posts: 12299 Rating: (2691) |
Hello Haider; The implementation of PID (or PI) controllers varies amongst the different manufacturers, which can lead to some confusing discussions. What you are looking at right now if the dichotomy of Reset Time (in sec. per repeat) versus Reset Rate (repeats per second). In this context, "reset" refers to the time given to the integral component to match the action of the proportional part of the control algorithm. So the smaller the time allowed (or the larger the rate, since it is the inverse) the stronger the integral action. One great ressource I follow for PID controls is controlguru.com. The following extract can appear trivial, but start following the links and you will soon discover a lot on cntrol theory, as applied in PLCs: Reset Time Versus Reset Rate Tr = 1/Ti No matter how the tuning parameters are expressed, the PI algorithms are all equally capable. But it is critical to know your manufacturer before you start tuning your controller because parameter values must be matched to your particular algorithm form.Commercial software for controller design and tuning will automatically address this problem for you. |
