11/1/2023 8:38 AM | |
Joined: 4/9/2014 Last visit: 2/12/2025 Posts: 11 Rating:
Hi, First you need to change the FW version for you panel in the TIA project. To do that you need to open Device configuration and after that right click on the panel and "Change device". Find your HMI panel with FW version 17 (You are using TIA 17). After you finish with your project you need to update the FW version of your HMI panel. Click on the HMI panel in device configuration and go to menu Online > HMI Device Maintenance > Update operating system. (To do that first you need to have images for that panel in your PC) If you don't have the image you are able to download it from hire. At the end of the OS update you will be able to download your project. |
Last edited by: R.Raychev at: 11/01/2023 08:41:46Last edited by: R.Raychev at: 11/01/2023 08:42:23 |
