8/18/2009 6:14 PM | |
Joined: 8/31/2005 Last visit: 4/24/2023 Posts: 2194 Rating:
You must set the PROFIBUS address that is configured in the PLC Program (in STEP7 this is defined in HW Konfig), see attachment. You can try to find it out, by setting a address, repower the ET200, if there is still a bus fault: trying the next adress, repower the ET200, check the BF, sent next address, repower, check ....... Attachmentet200S_operating_instructions_en_US_en-US.pdf (103 Downloads) |
8/19/2009 5:37 AM | |
Joined: 12/5/2006 Last visit: 5/26/2023 Posts: 177 Rating:
Thank you But from Hard ware configuration, were I can Find which is correct DP Address . Pl Explain Regards Pudur |
8/19/2009 6:59 AM | |
Thanks |
