8/2/2020 12:09 PM | |
Joined: 9/27/2006 Last visit: 6/3/2023 Posts: 12033 Rating:
Hello leanko; The following link allows you to download the various DP/As-i link gsd files. You can use the DPV0 version of the gsd file for the 6GK1415-2AA01 in your project. https://support.industry.siemens.com/cs/ww/en/view/113250 I suggest you do the migration after having removed the instance of the DP_As-i link from the Simatic Manager project, then import the gsd file in the migrated TIA Portal project to integrate your module and program it. More information in using the 6GK1415-2AA01 with its gsd file can be found in the following manual: https://support.industry.siemens.com/cs/us/en/view/5281638 Hope this helps, |
8/2/2020 9:37 PM | |
Posts: 2 Rating:
Thank you a lot. It helped me. |
