9/30/2009 2:01 PM | |
Posts: 557 Rating: (64) |
HI i am using a S7 400 H system, can i communicate DP-DP coupler on Y link with other master system.if yes please send me the link or manual.. regards |
10/1/2009 9:53 AM | |
Joined: 2/27/2008 Last visit: 2/1/2024 Posts: 3 Rating: (0) |
Dear Eastern, you can configure an Y-Link on your H-System, so you will get a new PROFIBUS DP network from this Y-Link. Now, you have to plug your DP/DP Coupler on this new network to use it with both CPUs of your H-System. The another side of your DP/DP Coupler has to be configured in the another PLC, so you will be able to communicate both DP Master. In this manual http://support.automation.siemens.com/WW/view/es/1142696 chapter 8 you will see the examples to configure this. I don't know if this is the information you wanted, but I hope this could help you. If you need something else, let me know. Best regards, Ramón |
4/10/2018 3:16 PM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (174) |
New question published by TATAY is split to a separate thread with the subject Hardware is not getting online. Best regards |
