10/5/2016 2:02 PM | |
Joined: 4/4/2011 Last visit: 3/24/2023 Posts: 65 Rating:
Hello! Take a look at the following FAQ here and at the manual of the DP/ DP Coupler here for correct configuration. From your picture I see that the DP/ DP is terminal node for both networks so make sure your terminal resistors for each Profibus connector are in ON position. Hope it helps, Mihai. |
Learn, unlearn, relearn... |
