9/17/2019 12:30 AM | |
Joined: 9/27/2006 Last visit: 6/5/2023 Posts: 12034 Rating:
Hello Ted; A DP/DP coupler is a special Profibus-DP slave, with 2 slave interfaces, that connect to 2 distinct DP-masters and allows them to exchange data between them. You insert one DP/DP coupler instance on the Profibus network of each master, and configure the data exchanges as described in this document: Configuration of I/O exchanges on a DP/DP COUPLER https://support.industry.siemens.com/cs/ww/en/view/19281019 Hope this helps, |
9/17/2019 12:39 AM | |
Joined: 3/14/2017 Last visit: 6/5/2023 Posts: 96 Rating:
can i insert dp/dp coupler in my hardware configuration? with regards ted |
9/17/2019 1:15 AM | |
Hello Ted; Sorry my first reply did not clarify the issue well enough. You insert a DP/DP coupler in the hardware configuration of each master you want to interconnect. The best source of information on any Siemens equipment is always the manual: https://support.industry.siemens.com/cs/ww/en/view/1179382 Study especially chapter 4, Configuring and commissioning. Hope this helps, |
