3/5/2015 7:46 PM | |
Joined: 1/28/2009 Last visit: 8/8/2023 Posts: 6818 Rating:
Hello, If you are sure that there is a problem in your DP Port, I think you need to send the CPU to the nearest repair-shop of SIEMENS Industry and ask them for help.Find contact data here . To be sure, test again your CPU with new PROFIBUS connector and an intact slave.Check the test for different baud-rates.If it doesn't work this manner, do as mentioned before.Otherwise there is problem in your PROFIBUS set-up. I hope this helps, Hamid Hosseini |
3/6/2015 7:06 AM | |
Posts: 1058 Rating:
Hello Habib Nader, maybe you can describe your problem here in detail. Without a description it will be hard to help. regards |
3/7/2015 8:51 PM | |
Joined: 1/21/2013 Last visit: 6/21/2023 Posts: 4617 Rating:
Hello, What type of PC adapter you have? Try to change settings in your PG/PC Interface
