5/3/2017 6:19 PM | |
Posts: 2826 Rating:
Check if "Access from HMI" is set in the DB where the tag comes from. |
5/3/2017 6:41 PM | |
Joined: 9/16/2014 Last visit: 1/11/2025 Posts: 30 Rating:
Yeah, it is enable. When I do the same using HMI variables it works fine, the problem is from variables of PLC. Regards |
5/29/2017 2:34 PM | |
Posts: 648 Rating:
Hey all, in my projekt drag & drop works fine. You can make a service request through Siemens. https://support.industry.siemens.com/cs/ww/en/sc/2090 It can be possible, that your project is damaged. With best regards rh1990 |
