2/22/2022 1:55 PM | |
Joined: 2/6/2015 Last visit: 11/28/2022 Posts: 83 Rating:
Hello I want to draw a trend from the datas that i read from a csv or text file. (not a real time trend, the data is read from an ODK aplication in advance). How can i realise this? If I use a normal trend, and define a tag for data source that would not possible. If i define a log as data source, then i should be able to log data into this log via a script. In WinCC Advanced this was quite easy. But I cannot see a function for that in WinCC Unified. How should I proceed? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/23/2022 07:32:35New subject after splitting |
2/23/2022 4:09 PM | |
Thank you so much, last question: Should i prefer normal trend or function trend? |
