11/19/2014 8:44 AM | |
Posts: 1299 Rating:
Hello, do you want to rotate the graphic smoothly or just show one ofthese 3 static pictures? K!ke |
11/19/2014 9:45 AM | |
Joined: 10/23/2014 Last visit: 2/1/2023 Posts: 199 Rating:
yes i need the rotation to be smoothly please i need written steps if you will use scripts thank you |
11/19/2014 2:47 PM | |
Posts: 1299 Rating:
Hello, you can do this with a graphic list, similar to what they do in this example: http://support.automation.siemens.com/WW/view/en/48052573 K!ke |
11/19/2014 2:59 PM | |
no i need the drawing in atached file not gauge |
11/20/2014 7:51 AM | |
Posts: 1299 Rating:
Hello, you can adapt this example to your problem. instead of pictures of the gauge you insert pictures of your drawing. K!ke |
11/21/2014 2:16 PM | |
i wait for your answer |
12/9/2014 10:40 PM | |
are not there any solution for my problem? |
