12/12/2012 7:26 AM | |
Joined: 10/7/2005 Last visit: 11/14/2024 Posts: 3027 Rating: (1057) |
Hello Arun_Kumar the difference will most probablybe caused by compoundingthe ever so small rounding errors that take place inthe REAL format calculation inside "TIMER_P" every time it is called. You'll find asimilar discussion and more detailed analysis of this TIMER_P "problem"in the thread FB5 confusion. I don't knowwhat call rate your OB35 has, but in case it isn't 1 sec, do a trialofmoving these TIMER_P calls into a 1sec cyclic Interrupt OBand see if it improves the situation. I hope this helps |
Cheers |
