8/18/2011 12:05 PM | |
Posts: 14 Rating:
hi for all members after dowloaded this link http://support.automation.siemens.com/WW/view/en/43283535S7-1200_ClockAlarm.zip( 335 KB ) and converted to tia SP1 cannot compile FB2 . here is the scr shoot how can i compile it? thanks cpu 1214 dcdcRly fw1 Tia v11 sp1 win7 pro sp1 en |
8/18/2011 3:53 PM | |
Joined: 7/7/2010 Last visit: 12/9/2023 Posts: 13994 Rating:
What version of the PLC firmware are you using? You may need to perform a 'change device' to clear that up as the DTL data type still exists. There is also an update to SP1. The update may address this problem. If you install the update, I would probably perform the conversion to V11 again. |
science guy |
8/18/2011 4:19 PM | |
Posts: 14 Rating:
my cpu 1214 Firmware is v1.02 is there any update after TIA sp1 ?? i will try your suggestions thanks |
8/24/2011 10:43 AM | |
Joined: 5/28/2008 Last visit: 12/1/2023 Posts: 1343 Rating:
Yes, there is an update for SP1. Look here: http://support.automation.siemens.com/WW/view/en/52258326 There is also an problem with DTL-datatype in SP1. Hopefully it will be fixed soon. |
