7/24/2013 4:14 AM | |
Joined: 9/27/2006 Last visit: 4/19/2024 Posts: 12256 Rating: (2664) |
Hello Yarek_; Welcome to the Forum, although we generally do not expect to be used as a shoulder to cry on. As you say, you are a beginner with Siemens products, and Siemens products require some work and experience to get used to. They are not designed as user-friendly as some other automation products I have used elsewhere, I freely admit it, but most people here have not only learned to use them properly, they have managed to master them quite well. One of the best tools available to learn tricks and tips to program these CPUs is here, in the forum, in the guise of the Search box at the right of thos page. Try it before frustrating even more. Use "DTL Tia Portal" as a search string, or any other that fits your requirement. My search on "DTL TIA Portal", with the selection of the FAQ filter, brought me directly to this thread: In STEP 7 (TIA Portal) V11, how can you input, read out and edit the date and time for S7-300/400/1200? There were 4 more posts along the same lines, any of which can explain and demonstratehow to read, write and manipulate date-and-time data formats. There is even a sample program attached to the FAQ that will guide you in using the appropriate functions. Hope this helps, Daniel Chartier |
