6/8/2012 8:09 AM | |
Joined: 3/21/2006 Last visit: 12/18/2022 Posts: 10221 Rating:
Hello, Is that 'settings' are the same with your PC? Best regards, Hristo Mihalev
7/10/2012 8:06 PM | |
Posts: 33 Rating:
my plc or my computer?my problem iswith the winCC of TIA |
7/11/2012 4:00 PM | |
Posts: 3037 Rating:
Hello, Which panel do you use in WinCC V11? Do you use Advanced or Professional version? In STEP 7 (TIA Portal) V11, how can you read out the values in the "DTL" format and display them in the "BCD" or "Dec" display format? Tweety |
7/11/2012 4:33 PM | |
Posts: 33 Rating:
TIA V11 sp2 S7 PRO V11 sp2 WinCC PRO V11 sp2 I dont want use a new variable with a DTL modified. |
7/16/2012 2:09 PM | |
Posts: 33 Rating:
look at the difference between the panel and windows |
7/16/2012 4:26 PM | |
Posts: 3037 Rating:
Hello, WhichEditing language do you use? You can not change the Regional settings on a KTP 600. Tweety |
