5/2/2016 10:58 AM | |
Joined: 5/28/2008 Last visit: 9/12/2022 Posts: 1343 Rating:
YOu can try to display the single elements from the DTL format (like tag.hour, tag.minute, etc..), separated by your wished signs. So you should be able to built-up an own kind of time format. |
5/10/2016 7:01 AM | |
Posts: 84 Rating:
Sir, I had read the parameters separately to the HTML as you mentioned but i don't know the html code to combine all the variables day month year hour minute and seconds to a format like 10/05/2016 and 12:00:00. by adding the separators "/" and ":" So please help me to combine all this variable to a format i mentioned above. |
5/10/2016 3:55 PM | |
I'm also not HTML expert. I would built a string inside the PLC and access the String-Tag from HTML. |
