10/5/2022 10:08 AM | |
Joined: 12/16/2016 Last visit: 1/6/2025 Posts: 13 Rating:
I'm adding a sequence number to my alarm which works but when the alarm is acknowledged the dynamic text appears to be updated with the current value and I want it to remain the value it was on activation as the sequence number may have moved on. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/06/2022 08:31:34New subject after splitting |
10/6/2022 9:26 AM | |
Joined: 7/19/2022 Last visit: 4/17/2025 Posts: 436 Rating:
Hi AutoGen_6210416, Directly in the alarm text I don't think you can keep the value with which the alarm was triggered because it is associated to the variable and it changes with it. But maybe by programming you can pass that value to another variable and put that variable in the alarm text.
Last edited by: JBS98 at: 10/06/2022 09:28:45Last edited by: JBS98 at: 10/06/2022 09:29:22Last edited by: JBS98 at: 10/06/2022 09:30:40If this Information really helps, you could use the Rate function |
