10/13/2021 4:33 PM | |
Joined: 7/1/2021 Last visit: 1/26/2024 Posts: 4 Rating: (0) |
Hi bergmanu, I've followed step by step the guide in the "Install_Eclipse_SDK_Linux_V1.1.pdf" but I haven't been able to make the IoT2050 run my project. Eclipse gets stuck "Launching New configuration" (image0.png) (like the guide says I've used the IOT2050 example image v1.1, the SDK-IOT2050-Debian-Arm64 and Ubuntu) First of all, the build has been completed successfully, as you can see in image1.png. Also there are two errors (image2.png) that i didn't know how to solve (I supose they are related to the paths (image3.png)). But the build is completed successfully so I suppose they are not the problem, are they? (The conection with IOT2050 is done correctly) I don't know what the problem is, i hope you can give me an answer. Thank you and best regards. ------------------------------------------------------------------------------------------ Attachmentimages.zip (488 Downloads) |
Last edited by: Jen_Moderator at: 10/14/2021 08:52:38New subject after splitting |
1/17/2022 8:34 AM | |
The version used is 2020-03 (4.15.0) Best regards |
1/18/2022 8:59 AM | |
okay, thanks. I will try that. I'll cross my fingers. |
