7/13/2023 9:57 AM | |
Hello AutoGen_2320668 Thank you for you feedback I Think you can also set any of the settings and then read out the value in Runtime to see which Value is used. Or perhaps its the same as in WinCC V7/8: https://support.industry.siemens.com/cs/ww/en/view/109818193/139460860043 Bye Murof |
