6/17/2018 11:11 PM | |
Joined: 3/11/2007 Last visit: 12/5/2022 Posts: 220 Rating:
Good evening, how do you make an electronic cam with the S7 1200? Is there any documentation, or an example? Thank you
6/18/2018 10:40 AM | |
Joined: 8/31/2005 Last visit: 1/23/2023 Posts: 2194 Rating:
I assume you want to use a cam function (not a cam switch). Have a look on the FB LGF_NonLin (https://support.industry.siemens.com/cs/ww/en/view/109479728), maybe this is a solution for you. If you want to use a cam for motion control, you should use a S7-1500T, the S7-1200 and S7-1500 does not support the cam function |
