5/28/2009 3:50 PM | |
Hi What WinCC version you use? In WinCC 7.0 What do you mean with layout? Different colors? Differrent Values Do can run a script on button-click, which change the colors. You can switchbetween the design in the configurationdialog. You can set time- and value-columns visible. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
5/28/2009 5:55 PM | |
Joined: 3/24/2009 Last visit: 8/7/2023 Posts: 406 Rating:
Hi... Thanks for your reply... I am using WINCC V6.2.... Actually i have to combine the two wincc online table control in one layout and then output them together. I also tried in a single layout with two different table control values.But i got the values of single table control values two times.... I also attach the (document image) report which was i got in the runtime........ Attachment1243427226_Print Job001.zip (46 Downloads) |
All is well :-) |
5/29/2009 10:48 AM | |
Hi Sorry, i did not understand, what do you want to do. Do you want to display the values of thetwo table control in runtime or in report. regards cumulus |
5/31/2009 9:29 AM | |
Hi... I also attach the report format for your reference.... How to obtain this in wincc ? I also tried usingtable control but it is not 100%....... AttachmentREPORT FORMAT.zip (45 Downloads) |
All is well :-) |
