3/30/2020 6:22 PM | |
Joined: 4/28/2015 Last visit: 12/4/2022 Posts: 43 Rating:
Hi DavidBrown, you only need to enable an external encoder if you want to do passive homing for an incremental encoder. However, since you own an absolute encoder, you can't passive home, so don't mind MC_Power The SICK ATM60 is a 13 Bit multiturn encoder. You have to set your encoder type to "Cyclic absolute". Set your fine resolution to 0. Also for reference here is a good FAQ on how to setup your TO for your external encoder: How can you realize the encoder configuration for the “positioning axis” technology object? |
