6/16/2016 10:23 AM | |
Posts: 6 Rating:
hi all ! how can i enable UDP161(the snmp protocol) in s7-1214 AC/DC/Rly(firmware v4.1.3) via TIA Portal? thanks! |
6/16/2016 10:54 AM | |
Joined: 7/9/2015 Last visit: 3/21/2025 Posts: 4204 Rating:
Hi, your S7-1200 CPU supports UDP and also SNMP Protocol (Firmware >=2.0) over integrated PN interface. If you will communicate to another device you can do this i.E. with TCON instruction to parametrize your connection. With TUSEND you can send data over UDP to partner device and with TURCV you receive data from another device Check S7-1200 manual please. https://support.industry.siemens.com/cs/ww/en/view/109478121 Regards, Towome |
