6/20/2017 1:35 PM | |
Joined: 2/5/2011 Last visit: 11/28/2022 Posts: 90 Rating:
Dear All Dose any body know how can I specify the direction of encoder rotation in hsc s7-1200? Thanks in advance |
6/20/2017 2:44 PM | |
Joined: 2/2/2015 Last visit: 11/30/2022 Posts: 123 Rating:
Hi ACDC24, After activating HSC, go under function properties then select ( Operating Phase: Single Phase ). This way will ensure one pulse unidirectional counting with a direction which is controlled by HSC_CONTROL, you can also determine the direction either internally or by using external input as your demands. This Topic will surely help you. Hoping to find this answer well. Regards; Ahmed Kadry |
