10/23/2019 1:52 PM | ||
Joined: 4/14/2010 Last visit: 9/18/2023 Posts: 514 Rating:
Greeting, Looking for alternative Pressure Transmitter in Siemens https://www.endress.com/en/field-instruments-overview/pressure/Absolute-Gauge-Cerabar-PMP55
MS |
10/23/2019 3:52 PM | |
Thank You! Daniel Chartier Looking for Replacement of Endress PMP55-BD21JA1PGBU7JA5B+AA in Siemens SITRANS P |
MS |
10/24/2019 3:29 PM | |
Joined: 9/27/2006 Last visit: 9/22/2023 Posts: 12152 Rating:
Hello MS; Sorry for the delay in replying, it is always an arduous process to determine an instrument part number, taking into account all the parameters involved. I have used the Siemens Industry Mall (Electronic catalog) online configurator to setup a SITRANS P DSIII as an equivalenet to your Cerabar M PMP55, as best I could. https://mall.industry.siemens.com/spice/pcmplus/app/ You should use it to review the selections I made, and tweak it if you find options and setting that best suit your application: https://mall.industry.siemens.com/spice/pcmplus/app/ To obtain price and delivery (unless your company is registered as an acknowledged user in the Mall) for your selected part number you should contact your nearest Siemens Rep. If you need to locate them, use the Contact & Partners link at the right of this page. Hope this helps, Daniel Chartier Edit: I just read danw's post above, i defer to his experience in instrumetation for his recommendation. You can use the same configurator for the SITRANS P300, search for SITRANS P300 in the Industry Mall, you will see links to the configurator next to the different models offered. D.C. |
10/24/2019 3:46 PM | |
Thank You! Daniel Chartier, We have selected following MLFB according your comparative recommendation Is it Suitable. 7MF4133-4DA70-1RB6-Z P00+R04 Attachment7MF4133-4DA70-1RB6-Z.pdf (55 Downloads) |
MS |
10/24/2019 4:40 PM | |
Joined: 3/28/2010 Last visit: 9/18/2023 Posts: 976 Rating:
If the site uses caustic washdown, the stainless steel enclosure of the P300 (7MF8023) holds up much better than the painted aluminum housing of the DSIII (7MF4133) to the washdown. One paint scratch on the aluminum housing will expose the aluminum which will rapidly corrode (white oxide) with exposure to caustic. The exact same set of sanitary flange connection is available with for either model. https://cache.industry.siemens.com/dl/files/327/109765327/att_978391/v1/sitransp_p300_fi01_en.pdf |
