8/29/2008 10:04 AM | |
Posts: 9 Rating:
Hi, Thank you for the answer, Your point is correct you have to generate the instance DB again. But what my piont was that when weenter a address -a symbol tablepop-up windowcomes to help you select the symbol or adress of DB or I/Oto use in logic This thing happens in LAD/FBD language selected block editor but not with STLwhere i have to press Ctrl+ J to have thasymol table Pop-Up window. I'm attaching some Pictures so that u can understand my piont. Thank You, HMP AttachmentSnapShots.zip (29 Downloads) |
Last edited by: HMP at: 8/29/2008 10:06 AMLast edited by: HMP at: 8/29/2008 10:05 AM |
