6/20/2024 11:56 AM | |
Joined: 7/19/2022 Last visit: 9/13/2024 Posts: 384 Rating: (62) |
Hello blyshchak, This error usually appears if the IPE file has been created with a version higher than the TIA Portal that you are using to insert the device proxy: Updating a device proxy via an IPE file As indicated, it must be the same version or lower version |
