10/18/2024 2:17 PM | |
Joined: 5/6/2022 Last visit: 2/6/2025 Posts: 550 Rating:
Hi Roxy_18, Before I can give you an answer, could you please elaborate a bit more on the error? To see a little bit where the problem might be, it would be important to know the following questions: - When are you getting this error, when you try to connect via web client or at what time exactly? - Since when did you get this error, has it started to occur after any modification or update? - Does it only happen with a specific project in case you are opening a project? We look forward to hearing from you so we can find out more and see what the problem is. Best regards!
10/21/2024 11:46 AM | |
Joined: 8/3/2009 Last visit: 2/7/2025 Posts: 14670 Rating:
Hello Roxy_18 Check if you have made all important settings for the runtime/simulation: https://support.industry.siemens.com/cs/de/en/view/109806850 Bye Murof |
Last edited by: Murof at: 10/21/2024 11:46:58If this Information really helps, you could use the Rate function |
