10/17/2008 10:14 PM | |
Posts: 2661 Rating:
Hi, Try after installing latest HSP's: |
10/20/2008 10:40 AM | |
Posts: 4 Rating:
Hello. I'm sorry to say update of HSP's didn't help. I still get wrong values for the S5-adapter. Regards |
10/20/2008 6:06 PM | |
Posts: 2661 Rating:
Hi, Can you post your porject (strip everything except HW Config)? I tried with a sample S5-adapter configuration and it works fine... Regards |
10/26/2008 12:50 PM | |
Posts: 4 Rating:
Sorry for the late reply. Here you have the stripped AS project. AttachmentPcs017_stripped.zip (183 Downloads) |
11/4/2008 9:52 PM | |
Posts: 2661 Rating:
Hi IVes, I tried with your project and a brand new project on my machine and encountered the same problem. After some trial & error, I found that for up to 10 input and output address entries, the export is good. But if you introduce a 11th entry, the export gets corrupted! Please report this to the Siemens Support so that they can issue a fix. In the meantime you need to use the good old cut-paste technology! Regards AttachmentDokument1.pdf (212 Downloads) |
