9/30/2022 3:35 AM | |
Joined: 6/14/2015 Last visit: 1/24/2025 Posts: 247 Rating: (2) |
Hello every body. I have F.7950 fault in my drive. what dose that mean? |
9/30/2022 5:04 AM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating: (880) |
Hello, With V-Assistant go on line & check. You will get detail information. |
9/30/2022 5:33 AM | |
I have connected with Tia Portal. ''' Module exists. '' |
9/30/2022 6:14 AM | |
Check & compare online servo motor parameters with actual connected motor specifications. |
9/30/2022 9:18 AM | |
when I want to select motor, I have this error . what should I do? |
10/4/2022 5:03 AM | |
Is your motor with absolute encoder? If yes, it should get detected. If with incremental encoder, you need to select motor article number from drop down list displayed in motor selection tab. Please refer SINAMICS V90, SINAMICS V-ASSISTANT Online Help manual for more detail information. |
10/5/2022 4:57 AM | |
My motor is incremental encoder. in online mode I couldn't select because it has error that I have shown above . in off line mode I can select , but how can I download off line project ? |
