3/16/2009 6:43 AM | |
Joined: 3/21/2006 Last visit: 11/14/2023 Posts: 10222 Rating:
Hello Check if your settings for autostart is OK. Deppends fro SimaticNet version hat you used How do you configure the WinCC Autostart when using SIMATIC NET (2005) or How do you configure the WinCC Autostart when using SIMATIC NET (up to and including CD11/2003 SP1)? Hope this will helps. regards |
3/25/2009 12:03 PM | |
Posts: 1776 Rating:
Maybe you need a delay for the autostart as on the above FAQ is mentioned. |
