4/21/2014 10:46 PM | |
Joined: 7/7/2010 Last visit: 12/11/2023 Posts: 13998 Rating:
It usually means your project is corrupted in some way, or, you need to reboot your PC. You might try double-clicking a known good copy or backup of your project and cause the portal to open that one (back it up first!). If that does not work, you may need to repair your portal installation. It could be a language issue, or a username or file path with characters the portal software does not tolerate. If it has worked great for a while and suddenly quit, you may have a corrupted project, or some small part of your project is corrupt. You can always send it to Siemens tech support via : Support Request |
science guy |
