7/7/2009 9:05 AM | |
Posts: 382 Rating:
Dear Zman, Is it possible to post you netpro/hardware configuration/system topology here? let's confirmed the setup is ok first. with regards, how come? |
7/7/2009 3:44 PM | |
Posts: 107 Rating:
have you tried swapping the sub modules / CP's |
7/7/2009 4:10 PM | |
Joined: 10/7/2005 Last visit: 3/30/2023 Posts: 2962 Rating:
Hello Zman I suggest you put some capture logic into your PLC and "grab" the error information from your communication Blocks to be able to work out what is going on. You should already have the manual for the Modbus Slave loadable driver (it comes withthe driver for the CP441). Have a look at its "diagnostic of the driver section". You may also need to cross reference the CP441 manual in which you find some detailed info on the so called SYSTAT area. No silver bullet here I'm afraid, but I hope this helps anyhow. |
Cheers |
