8/22/2020 9:23 AM | |
Joined: 7/31/2020 Last visit: 9/21/2023 Posts: 21 Rating:
Is the voltage supply within specifications? You said you've tried updating the firmware, did you follow the exact procedure as described below and did you use an authantic Siemens MMC? https://support.industry.siemens.com/cs/br/en/view/77492231 To be honest i'never seen this on any 1500 CPU so i think you are in bad luck and will have to contact Siemens if the above steps didn't work... i'm sorry |
Last edited by: VeulemansJens at: 08/22/2020 09:28:06Last edited by: Jen_Moderator at: 08/24/2020 09:29:31Optimized link. //Jens |
