10/28/2009 8:09 AM | |
Joined: 3/21/2006 Last visit: 1/14/2025 Posts: 10239 Rating: (1182)
Hello, You could start with check of DCOM configuration. Look at Configuring the DCOM interface in Windows XP SP2 |
10/29/2009 2:45 PM | |
Posts: 5822 Rating: (412)
Hello, I fear the problem is quite simple, you use the SIMATIC NET Software with an OS version it is not released for. If you check the FAQ: Which SIMATIC NET software component is enabled for which operating system? you will find that the Edition 2006 is only released for the SP 1 and SP 2 of Windows XP. As you have SP 3 you would need the Edition 2008. I am sorry about it. Best regards J_Bell |
