8/17/2018 10:06 AM | |
Hello Alex which Exact TIA Portal Version do you use? Are you using this Tool: https://support.industry.siemens.com/cs/de/en/view/109562021 Do you have installed TIA Openness on this System? Bye Murof |
3/20/2020 1:25 PM | |
Joined: 6/8/2015 Last visit: 3/9/2025 Posts: 1 Rating:
I had the same error. The problem was the name of one graphic ended by a dot "." |
