6/2/2022 2:55 PM | |
hi BalaDeee, there is something not clear to me. Are you using a function in the HMI to import the csv-file or the PLC function for the recipe? Because of the conference of Step7(TIA) I guess you are using the PLC-function.Then you should evaluate the Status of the blocks. This FAQ shows how to do this: How do you evaluate the status of system blocks in STEP 7 (TIA Portal)?hope this helps, regards, |
FCK WAR! |
